Front Trunk Microswitch Replacement
My 98 Boxster's front trunk compartment light has never worked so I decided to investigate. I first swapped the light assembly itself with the exact same light fixture in the rear trunk and found both lights worked. I deduced that it must be the front microswitch and ordered a new one from Sunset Porsche in Oregon. The cost was: $43.13 plus $8.00 shipping to Washington State. The Part number is: 996-613-206-00 I removed the carpet trunk liner. The front trunk liner is made up of 2 sec
Edited by kbrandsma
Thanks for posting this. I now have a working light in my front trunk after living without one for about two years.
One note - If you disconnect the battery prior to installing the switch, the light won't come on immediately when you reconnect the battery. You will need to open the driver's door to re-power the circuit.
