Cylinder head sensor
doyle
My 993 starts fine and runs for about 10mins before cutting out as if switched of by a sensor. I have replaced the DME relay but the problem remains and so my next thought was perhaps a faulty sensor thinking the car is overheating and cutting the engine. I have located the cylinder head sensor and as usual it appears impossible to access by simply jacking the car up. Has anyone out there had experience of this? -any advice gratefully accepted. Thanks -Trevor
take the wheel off and put a bag over the brakes, to stay clean. follow the wire down to the grommet on the sheet metal. pop the grommet loose and you will see the sensor, you need a slotted socket to install the new sensor so you don't cut the wire
