Headlights, wipers.
dumas42
I have an 86 928s I just started a rebuild and before I go to far I would like to solve a couple of problems. 1) no front windshield wipers, they are not working at all and I'm not sure if I should start with the relay or not. 2) all lights work except the headlights, checked the headlight and it works, now I need an idea as to where to go next? Can you help?
front wiper is fuse#5 15amp, if fuse is good wiper motor may have froze due to non use, try taping lightly with a hammer or wrench to see if that unfreezes it... otherwise you may be looking at a replacement motor
