I have a 2006 C4S that the brakes just recently started squealing on. Is 20k usually about the time for brakes? I drive it daily and push it on the roads but havent been running on a track. Thanks.
Your wear sensors are not audible they are electrical and light a light on the dash.
You need to look at the pads thickness to see if they are worn enough to replace.
Most brake squeal is from moisture or lack of anti-squeal paste behind the pads.
thanks
