I might get it next year at an auction.The auction will be held again in few mths time around next year.
I saw this 928 at the auction last few mth. The car starts fine but the digital milage is not working.Is that ok? It's not driven since 1991. Like new condition.
And if there's other 928 at the auction, i might go for that. What to look for? Most cars have being stored.
928 didn't get a digital dash until '89, broken speedo in earlier cars is quite common (as it is with most Porsches)
buying at auction generally doesn't get you previous service records, so unless there are records plan on doing the timing belt/water pump job
the unibody is galvenised so rust isn't usually an issue, check suspension for torn boots/bushings, check all electrical components if allowed (windows, sunroof, lights etc).... since this car has been sitting since '91 you'll probably need to replace a good chunk of the rubber, double check fuel lines, tb/wp, flush all fluids.. etc, etc like any other car that's been sitting for 15+ yrs
Thank you for the response.
Well here's the list of the Porsche being sold at the Auction. But plz note some cars have been sold previous auction which I did not manage to get it. I might though in the next Auction if there's other 928s..
http://www.autotitre.com/forum/Sultan-de-b...age-78242p1.htm
POR 928 S4 BP2282 WPOZZZ92ZHS842022
POR 928 GTS BP2829 WPOZZZ92ZNS800486
POR 928 S4 BP2899 WPOZZZ92ZKS840224
POR 928 S4 BP2898 WPOZZZ92ZKS841579
POR 928 S4 BP2819 WPOZZZ92ZMS801603
POR 928 GTS BP2822 WPOZZZ92ZLS842002
POR 928 S4 BQ9843 WPOZZZ92ZLS842103
POR 928 S4 BP2289 WPOZZZ92ZHS840401
POR 928 S4 BH928 WPOZZZ92ZLS841269
POR 928 GTS BN9998 WPOZZZ92ZNS800492
POR 928 GTS BP2889 WPOZZZ92ZNS800982
POR 928 S4 BJ7959 WPOZZZ92ZHS840281
POR 928 S4 B9899 WPOZZZ92ZLS840831
POR 928 GTS BL9959 WPOZZZ92ZNS800680
POR 928 GTS BN928 WPOZZZ92ZR5800419
POR 928 S4 BJ9797 WPOZZZ92ZKS841232
POR 928 GTS BK8577 WPOZZZ9Z7NS801606
POR 928 GTS BK8198 WPOZZZ92ZLS842006
POR 928 BP2219 WPOZZZ92ZES841071
POR 928 S4 BP2820 WPOZZZ92ZJ5841944
POR 928 S4 BJ9753 WPOZZZ92ZKS842378
POR 928 S2 BJ7000 WPOZZZ92ZJS840532
POR 928 S KF8917 WPOZZZ92ZF3841333
POR 928 S4 BP2332 WPOZZZ92ZMS800489
POR 928 S4 BP2772 WPOZZZ92ZLS842418
POR 928 S4 BP2552 WPOZZZ92ZMS800396
POR 928 BP2838 WPOZZZ92ZMS800754
POR 928 GTS BN1030 WPOZZZ92ZRS800334
POR 928 S4 BP2328 WPOZZZ92ZKS842280
POR 928 GTS BN1022 WPOZZZ92ZRS800324
POR 928 S BH3751 WPOZZZ92ZFS840648
POR 928 GTS BP2298 WPOZZZ92ZNS808626
POR 928 GTS BN2888 WPOZZZ92ZSS800340
POR 928 S4 DPD WPOZZZ92ZLS840365
POR 928 GTS BL9289 WPOZZZ92ZNS800621
POR 928 GTS BK8118 WPOZZZ92ZLS841528
POR 928 S BL37 WPOZZZ92ZM5801301
POR 928 GTS KE9919 WPOZZZ9RZN5800989
POR 928 S BL2 WPOZZZ92ZMS800515
POR 928 GTS KE9917 WPOZZZ92ZPS800106
POR 928 S4 KE9988 WPOZZZ92ZKS840970
POR 928 GTS KE9916 WPOZZZ92ZPS800148
POR 928 S4 BJ928 WPOZZZ92ZHS841488
POR 928 GTS KE9918 WPOZZZ92ZNS800927
POR 928 S4 BH9573 WPOZZZ92ZGS841865
POR 928 S4 BL5512 WPOZZZ92ZLS841284
POR 928 BN978 WPOZZZ92ZJS840931
POR 928 BP2818 WPOZZZ92ZLS842013
POR 928 S 928S WPOZZZ92ZHS840295
POR 928 BN6188 WPOZZZ92ZJS840999
POR 928 GTS BM928 WP0ZZZ92ZNS000817
POR 928 S BM7480 WPOZZZ92ZLS842420
POR 928 S4 BL15 WPOZZZ92ZKS842470
POR 928 S4 KE1 POZZ2922HS841953
POR 928 S4 KE7925 WPO777922LS842409
BTW the Vin number. I know there's the vin decoder on this site but how do i tell the colour of the car? the vin decoder doesn't state it.
Loren is correct, vin doesn't give options... if you want to check 1 or 2 I would be happy to look them up for you
by that list I see the Sultan is finally liquidating some of his cars?
Thanks for the response. Well I'll see what comes out at the next Auction. I really hope I get the 928 next time.
No, the lists of cars belongs to the collapse Amedeo Corp.
http://www-cgi.cnn.com/ASIANOW/asiaweek/99/0813/nat1.html
Edited by zezeq
what auction company is handling the sales? is this an open auction?
the links you listed are old, just trying to verify current update
