Im having a problem with my lights, front low beam side marker and rear light don't work.
I have a blown fuse on A3, changed it but blows again as soon as I turn on lights.
Any ideas, anything else I can check before taking it to garage/dealer?
what about the relay?
When headlight switch doesn't work the fuse blows right away?
do you have the part number for the switch,
Is this a common problem?
thanks Loren
If it is only on one side then check the connector in the front fender first. Look for a broken connector, corroded wires, or pins pushed out of the connector.
Thanks for the quick reply Loren, thats what I thought at first, didn't check it 'cause
if it has anything to do with front connector or wires then what explains the rear light not working.
brake light is ok.
