1999 c2
When i turn on my fog lights or high beams my drivers side blinkers don't work. I've removed and checked all the bulbs and the look ok. Any suggestions before I go spend$$$ at the dealer to track it down?
hugo
I assume you have checked fuses? does the condition change if you wiggle the key in the ignition? If so it is the ignition switch...if not possibly the light switch.
