There are a couple of 'expansion rivets' (#28 in PET drawing below) in the front of the shelf under the steering wheel. Does any one have any tips on how to pop those out safely? :unsure: Mine really needs replacement, they're only $50!
Thank you,
Alex
The factory mount is with plastic rivets, in the middle sits a pin, push them out with a small phillips screwdriver or something similar, the rivet will fall on the floor. Metal pop rivets are, as Loren suggest, a better ( stronger ) solution.
