Trying to figure out which wire is for fuel indicator on instrument panel. (Cayenne 2008 Turbo) Do i need to clear any codes or connect PIWIS (trip to dealer) if i unplug and replug the dashboard? thank you.
There will be some communication codes present in the different control box memory's, but nothing showed on the dash display when driving.
Unfortunately i have no wiring diagram disposal, maybe there is a solution for "contributing members" ?
