Steering Wheel Makes a Rough Noise While Turning
Hi, annoying problem, after driving for 15 - 20 minutes, a noise will start inside of the steering wheel when turning in either direction. The noise is sort of a grinding metal on metal wet sneaker sound, obviously something is worn out or lacking lubrication. Any ideas? Thanks
ugh, new column. this was replaced a lot under warranty on early models
Dealer replaced the power steering rack, including the steering gear, part: 955-347-011-17 and the steering column sealing sleeve, part: 955-347-037-03
Drive is MUCH improved, nice "new car" stiffness, plus, it appears the noise is gone (fingers crossed)
