I have an engine check light. So i ran the durametrics diagnostic tool and came up with two faults
1- P0011 - A camshaft Position - Timing Over Advanced or System Performance B1 present.
2- P0344 Circuit bank 1 or Single Sensor No Signal / communication
Is it a camshaft position sensor that is faulty ?
Thanks for your help.
P0011 Adjustment of Inlet Camshaft in relation to Crankshaft, Bank 1 – Signal Implausible
Possible cause of fault
- Dirt in oil circuit
- Sealing strips on inlet camshaft adjuster faulty
- Oil pressure too low
- Mechanical fault in inlet camshaft adjuster
- Solenoid hydraulic valve faulty
P0344 Camshaft Position Sensor "A" Circuit Intermittent
- Camshaft rotor (phase sender wheel) damaged
Best to test it with a PIWIS tester to determine if the sensor is bad.
