Considering picking up this 1996 911 C4S; Ebay link: http://cgi.ebay.com/ebaymotors/ws/eBayISAP...ht_21103wt_1066
It's got 87K miles, and apparently has the following needs:
Replace Engine Compartment Lid Shocks
Replace Trunk Lid Shocks
Replace Drivers Window Switch
Reseal Engine
Reseal Transmission
Reseal Front Differential
Reseal Power Steering Rack
Front and Rear Brakes
Front Tires
Diagnose Check Engine Light
Think its going to go for around 24K - Worth bidding or stay away?
Reseal Engine
Reseal Transmission
Front Tires
eBay car buying is never a good idea unless you or someone you know can look at the car before your purchase. Also, this car clearly needs a ton of work. Knowing how bad prices are for parts, I would stay away from this one. If you really want a 993, wait this one out for a better example. PPI is ALWAYS a good idea, even after having a ton of research under your belt. Good luck with the search!
I wouldn't even consider this vehicle. Search for a 911 that has been maintained as this one will most likely nickel and dime you to the poor house.
