Hi Loren,
Can you confirm whether the standard lugs are 45 or 50mm in length? I noticed that the top/face has "GT" imprinted on it.
Thank you,
Jeff
Hi Loren,
Thank you,
Jeff
If you have spacers and the washer is red in color then they are 50 mm. Otherwise they are 45 mm standard length.
No spacers yet, that is actually why I was asking. I would like to add 7mm to push-out the wheels a bit more. I don't track the car, so I think I'm okay?
If you increase the offset by 7 mm you will need 7 mm longer bolts.
