There isn't one.
All checks are done electronically through your instrument cluster/onboard computer.
See your Owner's Manual for more details.
There isn't one.
No wonder, i saw it in the owner manual but thought there was a dipstick too.
Loren, owner manual said engine have to be idle. how accurant is the reading if engine is running?
You are measuring the oil in the sump - so if the oil is warm and the car is on level ground - then it is likely pretty accurate.
Porsche's are sensitive to over filling so don't be concerned if the it is not all the way at the full mark. Better to be a little below (IMHO).
