Trying to find a dealer/distributor for only the starter solenoid. I replaced the AOS and noticed the alt cable to starter solenoid was burnt by the solenoid. Apparently the cables decided to arc weld themselves to the 8mm solenoid connection. The soleniod cap cracked getting bad cables off. Does anyone know where to get just the soleniod???
I found the part numbers but can't find a dealer for just the solenoid....
bosch soleniod part number -- 2-339-303-277
Starter reman numbers ---
BOSCH 0-001-123-001
BOSCH NEWMAN SR0808N -- new
BOSCH REMAN SR0808X -- reman
LESTER 17804
LTD 17804
LUCAS ELECTRICAL EUROPE LRS1602
NASTRA S17804
NEW TECH N17804
OCA PLATINUM 17804
OE PLUS ST-1035
PIC # 120-333
PORSCHE 996-604-103-00
QUALITY 17804
RELIANCE 61354
WESTLING 72-17804S
WILSON 91-15-7205
WORLDWIDE 17690
Suncoast 17804
autoline XCL21234
hitest 17804
fitment cross ref:
911 SERIES 3.4L 1999-2001
911 SERIES 3.6L 2004-2008
911 SERIES 3.8L 2005-2008
BOXSTER 2.5L 1999
BOXSTER 2.7L 2000-2008
BOXSTER 3.2L 2000-2006
BOXSTER 3.4L 2007-2008
CARRERA GT 5.7L 2004-2005
CAYMAN 2.7L 2007-2008
CAYMAN 3.4L 2006-2008
Steve
Any official Robert Bosch automotive branch center should help you out.
BOSCH 0-001-123-001
LESTER 17804
LTD 17804
NASTRA S17804
NEW TECH N17804
OCA PLATINUM 17804
OE PLUS ST-1035
PIC # 120-333
QUALITY 17804
RELIANCE 61354
WESTLING 72-17804S
WILSON 91-15-7205
WORLDWIDE 17690
Suncoast 17804
autoline XCL21234
hitest 17804
fitment cross ref:
BOXSTER 2.5L 1999
Steve
I would try a auto starter rebuild shop in your area that would probably sell you the solenoid part if you aren't close to a Bosch supply location.
Demosan Good Luck!!
I have called many alt/starter rebuilders here in Texas and none of them have the solenoid. I contacted HiTest and they did not even have a core to rebuild... Not many of these things out there I presume..
RFM,
Do you have a contact number for the "Robert Bosch" dealer in the states? I tried www.bosch.us and searched for the part number but not dice..
Thanks in Advance,
Steve
RFM,
Thanks in Advance,
Steve
Robert Bosch LLC
38000 Hills Tech Drive
Farmington Hills, MI 48331
By telephone: 248-876-9000
By fax: 248-876-1116
Boschautomotive@us.bosch.com
