Hello !
I am intending to add an amplifier in the booth, but I have issues in figuring out how to pull the (cables 4x signal + 4x speaker + remote on/off) through the firewall of the vehicle. I do not have any amp today in the booth so I cannot "reuse" some cables at all. I found two rubber gromets, on on each side of the battery, but both of these were completely stucked with cables. Are there any else ?
regards,
Niclas
Hello !
regards,
Niclas
Not sure but mine went through the grommet on the drivers side on the firewall just behind where the wires are in the picture under the drivers side cover panel.
Edited by Mother
Ok,I found a rubber gromet which are not used at all just behind the battery, and coming in just above the pedals. I will use this one and seal with some butyl.
Concerning the negative connector for the amp, which is the best, to connect it to the negative terminal of the battery or to a earthing point ?
Regards,
Niclas
Regards,
Niclas
I used the body earth from the amp to gnd just behind my amp under panel on left side.
