I just got a 2001 Boxster, and tonight I went to check the cabin air filter (plugged solid BTW). In removing the plastic cowl cover under the "hood", I noticed that the rubber expansion plug that the Torx screw goes into is mangled beyond belief, obviously done prior to my getting the car. This also explains why that cover was so lose to begin with and the screw was barely tight.
Are these rubber expansion plugs that go into the top of the strut tower available from Porsche? Anyone know the part number, or do I have to order an entire passenger side cowl? The drivers side was fine. I checked the plug for any numbers at all, and there isn't anything on them.
Thanks for any insight you can provide!
Bill in Wisconsin.
999.500.092.00 rubber nut -- US MSRP $3.85 each
As a side note, Suncoast had one of these in stock shockingly. A whopping 2.70 cents too! My local dealer wanted close to 8 bucks.
