2001 996 TT Fuse Map
Hi everyone,
I started my car last night and just realized both low light beams weren't working. A/C was also not working, turn it to the max, no air comes out. I suspect it's burnt fuses. Does anyone have a fuse map for a 2001 996 TT? I found a fuse map for 2003 TT in this forum, but I'm not sure if it's the same as my 2001. Any help is appreciated.
Thank you kindly.
Raingion
Hi everyone,
Thank you kindly.
Raingion
:welcome:
There is supposed to be a fuse map on the inside of the fuse door/cover - did you look there?
Yea, looked everywhere in the car, manual also, nothing to be found. Thank you for your diagram Loren.
Raingion
Hi everyone,
Thank you kindly.
Raingion
:welcome:
  • 2 years later...
Sorry, this may be a really newb question. But would this fuse list apply to my 2001 996 C4 Cab? My fuse panel doesn't have a sticker either.
Thanks in advance.
Some but not all.
Did you check the fuse cover for a fuse listing?
If you still need the fuse listing then please post int he proper forum.
