Does anyone know if changing the drive belt is like a 996 Carrera? I have 66K on my S and want to know how to change it. I have checked most posting,but no details on hoe and if there is room to get to it. Thanks all
The "S" is approx. the same (NOT for TURBO), just a little more lack on room, make a drawing of the belt routing before replacing, it will make it easier to find out in case of doubt.
Thanks RMF, but how is the belt removed compared to a 996?
The same way as 996, there are no other parts to remove, slacken the tensioner with a big open key, remove and replace the belt.
While you have the belt off inspect all of the pulleys including the water pump for movement/roughness.
RMF, do you have a diagram? I do not know which one is the tensioner. DO happen to know if the bolt on the tensioner is a 24mm like on the 996? Thanks
Wvicary, what type of movement should i look for? How much movement should there to begin with? Do you know if there are any pics of drive belt replacement?
There will always be slight radial movement in all the idlers/tensioner pulley. Try and put a load on them while turning at the same time to feel any roughness. The water pump should have no play in the brng assembly and should be free of noise. Sorry I have no diagram at hand but it is very straight foreword if you take a close look at the belt system.
Which one is the tensioner to loosen the belt?
I'm rubbish at most of this computer stuff so I hope I did the attachment correctly. If you can't see it then I can PM it.
An open key is an ordinary key, looks like a wrench >> :wrench: fits on the tensioner hexagonal body, which is the pivot point, to slacken the tensioner (# 17 on "wvicary" diagram) It is not necessary to disconnect the coolwater tube to replace the belt.
An "open end box wrench" in our terminology. Thanks.
RMF, is #17 apart of 19? do you remove the black cap to find the hex bolt? I still finding it difficult as to which tensioner is the correct one and how to tackle it. Thanks
If the tension roller is still in good condition, nothing should be removed.
You want to use a 30mm open end wrench on the hex portion of item #17 of the parts diagram.
Ptec, thanks! but when you mean top portion, is there also another pully that needs to be loosen? or it just item 17 with the 30mm socket? Thanks Again.
Can the coolant hoses to the left and right of the radiator be removed to make more room to change the drive belt? I want to make sure coolant does not come pouring out.
