Help with a problem
- 2000 Boxster S w/ 57K
- Ran fine, left parked for 4 days
- While parked accessed the HVAC diagnostic and cycled through the menus with key on, engine off.
- Went to drive the next day and car starts but will not rev beyond 2K and has no power
- Barely able to get back into my garage
- Check engine light came on only after a few minutes of running, on constantly now
- Can press accelerator to the floor but no response beyond a slow increase in revs to 2K
- Once the accelerator is beyond 1/8 to ¼ throttle, the motor hesitates
- Idles fine except occasionally exhibits a drop in revs.
- Cycling the AC compressor exacerbates the RPM drops
- Removed the MAF and cleaned although it was pristine wit no evidence of damage or oil film.
- Put back in, no difference.
I realize my symptoms are consistent with a failed MAS, however before spending $375 I thought I would post for suggestions. Since I had absolutely no running problems prior and the problem started immediately after accessing the HVAC menu system, is there any correlation? I had the ignition key on with engine not running for approximately 5 min. I would think that would not cause a problem.
Thanks Henry Jay
MAF update
Cleaning did no god.
Took Highlander’s advice and left MAF unplugged
Car runs fine
Plug it in and symptoms return.
FYI the car will run fine with out MAF plugged in
Down on power and seems to have some “indecision” when changing from closed loop to open loop. Certainly drivable and capable of getting home. In fact I pulled the DME fuse to reset CEL and drove 5-6 miles with no CEL light.
Still have to wonder if messing around with the HVAC diagnostic readout caused the failure or is it a coinkydink?
Henry Jay
Did you eat a hamburger within 10 days of the problem. Maybe that is the reason. :D Coincidence. This A/C display thing is rather old stuff and it is there because the display came from an Audi and that is what they used. I have done this on several local owner's cars, including my own, and pushing the buttons is not going to kill an an air flow sensor.
If you can find another Boxster owner with the exact same part number on the sensor then swap them and drive around for a while, turning the car on and off once in a while. Then you will know.
Or have someone with an OBD2 code reader read the fault codes when the check engine light is on.
