help! 1999 996 C2 Manual convertible. Right Hand Drive.
was hit by a truck last Friday as i was driving through an intersection. The truck ran through the red light and hit me on rear right wheel area. the rear right quarter panel / lights /wheel were damaged. I drove the car 2 blocks back to my garage and only then found the rear wheel was bent out an angle. Now the car was towed to the penal shop.
My question is: apart from the obvious body damage, what mechanical damages maybe caused by the accident, and how to find out more?
Any help would be greatly appreciated.
Glad you were not injured.
Be sure and have them check the right rear suspension and brakes. If you you were hit hard enough to bend a wheel then the car took a pretty hard shock.
Might be a good idea to inspect and/or replace the engine mounts too.
thanks loren.
spoke to my panel shop and a porsche mechanical specialist today. was told that chassis, real axle, suspension/brakes will all be checked. rear right quarter panel and wheel be replaced. and any other things found along the way. will run a diagnose as well. last similar job they did on a 996 totaled AUS$35,000 (body work + mechanics). Guess i'd find out in 4~5 weeks time about mine :-)
