Hi Renntech friends,
I just purchased a 1984, 944 that I want to bring back to life. The car looks great, but I have a problem starting it. I need to turn the key very rapidly in the ignition switch in order for the car to start. A few quick turns and the car does start and stays on. but it is a pain, what parts do you think I need to replace?
Yes the engine cranks, but it does not stay on. You have to quickly turn the key 3/4 way and then it will turn on. If you just insert the key and turn all the way it tries to start but does not engage.
  • 7 months later...
Were you able to fix your problem ? I have a simler problem with my 87 944s
Sorry, Allen I just loged back in from many months ago. I'm sure by know you have fixed your problem but in case you haven't here it goes, in my case it was that the car was not building enough fuel preassure and I had to replace the fuel damper and compressor.
