My 86 gear shifter moves all over while in gear. I have to keep pulling it back to center. Its like it is not locked in. I can shift into all gears but it moves around like crazy until I'm in the gear. The whole handle rotates like 90 degrees even when in gear. Any ideas how to fix?
sounds like it is time to replace shifter bushings
At least the coupler bushings under the cover right in the "tunnel" at the center point of the four seats.
