What is the stock ride height at fender over wheel center front and rear (MY01)?
My ride seems too high in front.
I am thinking of gong with HR lowering springs in front and leaving the rears alone.
Any thoughts?
I am running 19" 315/25 235/35
Any thoughts?
First I assume you are at US height as opposed to ROW height. I would not recommend the set-up you suggest. It would be dangerous handling wise. You have the following options:
1. X73...The factory X73 retrofit kits lowers the US cars 40mm (1.6") in the front and 30mm (1.2") in the rear.
2. Coil Over set-up (JIC, PSSX, JRZ, Motons, etc.)
I run PSS9s (Euro version) with the same rims you have.
Edited by wross996TT
thanks--- I am talking US spec. I did not mention that I have a tip--don't know if that makes any diff
There may be different PNs for Tips...but the advice is the same
