Does anyone know where the X11 and X12 connectors are located in the MY99 Carrera with HiFi sound system?
I circled them in the diagram.
D.
Lower door - near hinge.
Thanks Loren. On the connector sheet its in the door grid (d7, k7). Does this mean that the wires connect to the speakers and then plug into another connector in the door? Aren't there connectors under the dash.
D. :huh:
As I recall the wire loom goes up behind the instrument cluster and then over to the fuse panel side and then passes into the door.
Thanks again Loren. I'll check it out this weekend.
D.
