hi all this is my first time here B)
i bought 2006 Cayenne S before 10 months
i would like to ask you about the engine with the gear
My Cayenne S is stock.. before when i start i let the car engine worming
for 5 to 10min and when i start moving normally the car start moving with 2nd Gear
not 1st one.
but now my cayenne changed it start moving with 1st gear and you know the 1st gear
like sport with high RPM not smooth then shifting normally 2nd 3rd...6th.
i let the engine worm for 20min but still the same start moving with 1st gear
i also change the engine oil with Mobile but still the same :angry:
its not normal because it was not like that how can it be solved?
Normal behavior for a stock Cayenne, please do a search, this issue is already discussed before.
