My car is a 2006 997 C2S. PCM Software version 3.3. I have read both TSB documents, which have conflicting part numbers for the NAV DVD drive:
997.642.137.02
and
997.642.157.00
Will either work?
Mike
You need to check your VIN against listings.
If you don't have the listings then PM your VIN and I will look it up for you.
I think I figured it out. My car was manufactured on 10/27/05 so the proper part number should be: 997.642.137.02
If you could confirm that would be great.
Mike
Mike
Yes, according to the parts list that should work.
