rough shifts with tiptronic when cold
Hi. On my 2000 C2 Tip, shifted moved all summer, fall, on cold days this winter, I notice a definite "bump" sound and lurch on many shifts?
Have you changed the transmission fluid? Mine can get a little 'jerky' when cold but I put this down a bit to age (10 years). You'll want to make sure the fluid is good.
If it's not suffering from RPM flare up between shifts, doesn't worsen over time and reduces the shift shock when hot then I wouldn't worry about it. Easy first step is to inspect the condition of the engine/transaxle mounts.
