I'm trying to figure out how to remove the side lights (parking lights/running lights...the ones under the actual headlight beam) in a 955. I can remove the headlight assembly, pull the cover off, and find the black plastic tab for the light, but it just turns round and round and never pulls out. The manual is completely unhelpful, simply stating to pull it out... it just doesn't seem to want to come out. I've tried the right and left headlight with no luck. Any help would be much appreciated.
If you mean the small bulb, take a pair of pincers and pull out the holder, sometimes it's hard to pull out by slight deformation cause the bulb heat.
Wow! You're not kidding... I used pretty much every ounce of strength I had (well, way more than I would have thought necessary) to get that thing out. I actually had to apply significant counterforce to the back of the headlight. It did come out ok though and went back just fine. Thanks for the tip!
