Servo/steering pump + belt replacement
911cedric
Hello,
i have a 1997 993 Twin turbo;
I'm planning to replace the servo pump and the belt as they are worn out.
I have a major leak coming from the pump body.
On the turbo, the servo pump feeds the clutch and steering system.
Does anybody know the easiest way to do it?
i have the technical schema of the unit, but i can't really figure out if i need to drop the engine or not to do the replacement.
i didn't find any helpful information in the workshop manual.
If anybody is familiar with this repair please share your experience!
Thank you
Best
servo pump.pdf
