I installed a FM modulator for my Cayennes with couple of M-F/F-M antenna adapters to the FM mouulator's Motorola plugs. In the back of the PCM II, it has the Europe type of male of antenna plug. After I plugged the "Europe to Motorola antenna adapter" to the back of the PCM II, it sticks out too far and I have hard time to put the PCM II back to the dash. Does anyone know who carry a "L" or 90 degree adapter for the European Antenna connector? Thanks.
Thanks Jeff,
The only problem is after put the adapter to the back of the PCM unit. the adapter pushes the antenna plug of the PCM and bent the antenna connector of PCM. I was able to put the unit back but I know the connector behind the PCM is bent. So I need a "L" 90 degree adapter for the antenna plug. I called Becker USA and they have it for $50.00+ including shipping. The guy at Becker said it is custom made from German.
