Okay, I searched on this DTC but found nothing. I recently installed some EVOMS diverter valves and ran into some issues. The DME shows DTC P2281 although the diverters seem connected okay. I did notice putting them in that there was a fair amount of oil in the drivers side boost hoses. There was also oil residue all around the area behind the drivers side intercooler above the lower boost hose. The drivers side Bosch diverter did have the vacuum line disconnected when I went to replace the diverter valves so not sure if that caused the oil spray. What is the best way to check for a boost leak under that DTC? I attached an picture of the area where the oil residue was mostly located... passenger side was dry.
Is this for a Cayenne or Carrera? You posted in Cayenne.
P2281 Leak Ahead of Throttle Valve – Below Limit/Above Limit
Possible cause of fault
- Leak between turbocharger and throttle valve
opps...looks like I need to update my signature! LOL This is for my 2004 Cayenne Turbo, the Carrera is gone.
Will be checking my diverter valves today and look at the boost hoses...
