I'm considering a 2004 GT3 with 30,000 miles on the clock. The DME reading follows. The range 1 revs says 65535 (2^16) and that looks like the limit of the computer's memory. I know these are the type 1 over revs and should be safe, but is that still too high? Does that indicate this car's been tracked? Anything else you guys notice about these readings?
Derek
GT3 DME Vehicle data
Number of ignitions, range 1
65535 667.1 h
Number of ingitions, range 2
Operating hours counter
789.0
Vehicle Identification Nr.
WP0AC29984xxxxxxx
Type ID DME control unit
0996GUS01
Order type
996810
Country code
C02
Engine type
9679
Transmission type
G9696
Transmission number
2002852
Radio/PCM code
0000
Body color/convertible top color
12H0L
Interior equipment
490
Number of programming operations
2
Navigation system
0000
Total distance
047364km
Edited by Loren
removed VIN from post
You have no Range 2 over revs - you can not ask for better.
Range 1 over revs were caught by the rev limiter and don't mean much since the rev limiter protected the engine. Range 2 are the bad over revs.
  • Like 1
  • 15 years later...
Hi there,
I am considering a car
Range 1 3000 ignitions
Range 2 600 ignitions
Should I be concerned ?
2 hours ago, CarPlebs said:
Hi there,
Model and year of the car please...
Sorry, I am such a noob!
2004 996.2 GT3, now I got the details (I guess I overestimated my memory :-D);
Range 1 approximately. 37000 ignitions
Range 2 approximately 4200 ignitions @ 703 hours
Car has now approx. 780 hours
I checked with my PIWIS the cam. dev. and both are in norm at bank 1 - 0 degrees bank 2 - 3 degrees.
Range 1: 7300-7500 RPM
Range 2: 7500-7700 RPM
Range 1 is likely hitting the rev limiter while accelerating. Likely safe.
I would not worry about any of those Range 2 over revs either - likely one missed downshift could do that.
Hi there!
according to https://911virgin.com/engine-revs/
and other sources on a 996 GT3
- range 1 is 8200-8800
- range 2 is 8800+
so I hope I am wrong because that would be excellent.
thanks !
9 hours ago, CarPlebs said:
Hi there!
- range 2 is 8800+
thanks !
Yes, you are correct I did not see the GT3 part - my bad.
