I pulled the codes on a friends cayman (2008) and the only code shown was p0016. I am very unfamiliar with the porsche piwis tester, but saw something about intake camshaft timing not matching with the crankshaft? Any thoughts as to what the code is suggesting I check. I dont believe the timing is off but i suppose anything is possible. Any advice would be appreciated.
:welcome:
P0016 Position of crankshaft in relation to intake camshaft
Possible fault causes:
- Camshaft sensor faulty (internal phase shift)
- Solenoid valve for camshaft adjustment soiled (does not close fully)
- Timing set incorrectly
Since your car is likely still under warranty I would let the dealer/OPC fix the issue.
