hi guys, I'm having a severe mis-fire after driving the car on the street for a few hours. It is perfect till that point. I shut it down for a few minutes and it's fine for 10 minutes till it starts to cut out again.
this will get expensive.
any ideas?
You need to determine if it's the secondary ignition system at fault or the DME injector ciruit. Do you know which cylinder is at fault?
It starts as a hesitation, then goes to bucking then it won't even pull itself on flat ground.
It feels like more than 1 cylinder when it progresses.
I let it cool for a few minutes and it fires right up on all 4 then the whole hesitation to bucking to it can't pull itself all over again.
The computer was relocated to under the glove box and now has a fan on it. Within the past 10 months they tried the crank position sensor, Rev sensor, and coolant sensor.
Start with the basics like fuel pump pressure and volume. It could be many things including a faulty ground or plugged exhaust. If your garage is just throwing parts at it hoping to find the problem then it's time to find new garage.
I have a straight thru 3" Lindsey exhaust with no cat.
The car got a new wiring harness for the battery ($238 part).
It went to a dealer which did the sensors and a race/street shop for the ECU relocate, battery harness.
do you think it could be vapor lock?
S
I highly doubt it's vapour lock but you need to test the fuel pressure and pump volume both hot and cold engine.
