I was in the process of jacking up my car to remove the tires when it dropped some oil in the back right and front right corners. The oil didn't smell like engine oil, but I can't figure out where the heck it came from. Looking at the engine I cannot see from under or above where the leak would have originated. I'm going to raise the car as high as I can on some stands and do a more thorough investigation tonight. Is this a motor mount failure I've experienced? I've got about 73K miles on the car.
I used the engine jack point as describe in this post. I am procuring a lower jack to use in the future so I can get it under the side of the car.
  • 5 months later...
This was also tracked in another post. I didn't realize at the time the were related.
The problem was from a failed motor mount. I replaced them with some cheap ebay mounts and one of them failed less than a month later. I replaced them with oem parts and haven't had any problems in months. The cheap ebay mounts were not hydraulically filled. My recommendation is to buy from a known vendor like Pelican Parts, as getting any customer service from ebay or the seller was a PITA.
