Hi guys
just scan my 2005 boxster and found some code, can someone help me with that,meaning of code and fix
vehicule electrical system:
code C127 communication front control unit(comfort)
No signal/communacation
Same code for instrument cluster,steering column electronics,radio cdr24
and for porsche access system-PAS plus code 8004 terminal 50 value below lower limit value.
Ben
by the way the car run well.
ok thanks again, can I do that with durametric.
Ben
Sorry, I don't think Durametric can do that. I think you will need to find someone with a PIWIS tester and the latest software updates.
