My car threw its first CEL in about 2 years....1999 996 w/99,200 miles.
Anybody know what this code means?
Thanks in advance,
- Cam
P1411 Secondary Air Injection Sy.stem - Signal Implausible (Cylinders 4 - 6)
Do you also have a P0410 Secondary Air Injection System - Signal Implausible (Cylinders 1 - 3)?
Possible causes:
- Wiring harness or fuse
- Relay
- DME control module
- Air supply lines
- Secondary air injection pump
- Electric change-over valve
- Air change-over valve
Possible causes:
- Relay
- Air supply lines
Nope, just the one code is all the reader showed.
If I can't find it, I guess it goes to my mechanic.
Thank you Loren, much appreciated.
- Cam
Edited by ZX9RCAM
