Hi all
I got a cel yesterday after the oil pressure sender went nuts and showed no oil pressure for about 5 seconds.
Can I reset this without any diagnostics equipment?
cg
Yes, it can be reset - but you really want to know the fault code(s).
Oil pressure should not have anything to do with a CEL. Oil pressure could be a bad connection on the sender unit or a bad sender (fairly common).
Hi Loren
how to perform the reset without diagnostic equipment?
cg
Disconnect the battery for 2 minutes -- but as I said you REALLY want to know what the fault code(s) were first.
