anyone know how to remove the air conditioning duct panel on the driver side? its attached to the light control switch.... my directional flaps in the duct is all distorted because its not fittin properly anymore.
i can't remove it like on the passenger side because of the light control switch. seems to be stuck pretty good, as if its still a screw i need to remove. i can only see the 2 torx screws on the side of the dash, nothing else.
tia
thanks!!!!! fortunately i went back and figured it out through frustration... i should've relaxed for a bit and waited for this post.
