Smoking Boxster S
I have posted prior about this issue and have corrected oil over fill issue and replaced A.O.S. When I turn left slightly uphill under high rpm leaving a light the car emits a large cloud of smoke, I do not burn oil otherwise. I can only assume due to the forces of cornering and exceleration the oil in the sump is forced into the A.O.S pickup. Is there a cure for this,ie:windage tray or better A.O.S, or is there a more serious problem i should be looking into?
2000 Boxster s
110,000 miles
Your advice is apreciated
Edited by frankahola08
It could be that old oil is just trapped in the intake manifold runners, it should cure itself with use. A small amount of oil can cause massive amounts of smoke so it might take awhile to burn away all the residue.
Double check TB you may still have oil residue there. I use wet/dry vacuum to suck and clean my TB tube. Wvicary is right it takes a long time to burn off oil out of the exhaust. Its embarrasing for sure to see boxster smoking:(
