Cayenne S instrument cluster problem
Hey everybody,
I have a bit of a confusing one on my hands and I am hoping somebody can help me out.
I have a 2005 Cayenne turbo, that has the digital cluster display out. I had a same model year Cayenne S that I swapped the cluster out and plugged in to the Turbo. The digital cluster gets illuminated with the Cayenne S cluster. Great the turbo needs a cluster. I go to put the cluster back into the Cayenne S and now it is throwing a fault code for WARNING AIR SUSPENSION. This vehicle doen't even have air suspension. The code that will not erase is 1310 level control module. I have tried with our PIWIS an durametric testers to remove the fault and it simply will not erase. I have coded the vehicle to steel springs and the code won't go away.
What can I do next?
Any words of wisdom would be much appreciated as we are really starting to pull our hair out over this one!
Cheers,
