My driver door sounds like a an old pickup truck door when It closes and latches.
It appears to fit square, the rubber looks good and I don’t believe it’t has ever been hit. I bought a special star type socket driver to adjust the latch and striker plate position to no avail. It made absolutely no. The car only has about 40k on it so I wouldn’t think It’s a question of driver side wear.
Are there any common problems any one knows about, items that wear in the door I should know about?
Regards, PK
Well, your car should have the new striker plate if it was built in late 1998 on (see TSB 2/99 5726). PM me your VIN if you want me to double check it.
You should also inspect it for looseness, corrosion and wear.
