Rattling noise from transmission
I just noticed a rattling noise from the transmission of my 2003 C4S with tiptronic transmission. It seems like it appears only when in third gear, or shifting up/down to/from third gear. Two months back, on trackday I experienced my transmission was stuck in neutral while I had the gear lever in drive. I shut off the engine and started it again, and the problem was gone. Can these two problems be related? Or have anyone experienced the same problem?
Thanks in advance.
Edited by thlangva
I am having the same problem with my C4S. Did you solve it? What was it?
Thanks.
Thanks in advance.
Yes I did. It was actually the front differential which needed to be replaced. Strange that it sounded like the noise were coming from the rear, when it really was coming from the front.
Thanks.
