Need assistance finding the speedometer wire
I am in the process of installing a GPS/Nav unit and having a ball doing it - though each step is somewhat of a gut wrenching moment. First and foremost, I'd like ot thank all the folks here on this forum.
After doing research thru countless threads on this forum, I gathered enough info to start this installation. Unfortunately, I am now at a road block and need some assistance. Thanks to this thread - "Where is the speedometer wire?" (http://www.renntech.org/forums/index.php?showtopic=747&hl=) - I have found the backup light wire and *almost* found the speedometer wire required for the GPS/Nav install.
My dilemma is that I pulled the relay support rack and popped out the connector in position 23. Sure enough there is a grey/pink wire there as described in the thread above - unfortunately there are 6 identical grey/pink wires routing into this connector. Which grey/pink wire do I tap for the speed signal?
Thanks in advance
