Hi all,
Happy New Year!
I'm helping a friend to replace the throttle cable, only the half that connects to the throttle body (the other half that connects to the gas pedal is fine). I tried to trace the cable but it just disappears behind the engine...
The WSM says there's a sleeve that the two halves of the cable can be disconnected so the engine can be removed. Does anyone know where exactly this sleeve is located? Also, do I need to lower the engine for this job?
TIA
