Any recommendations for replacing spark plugs? Am I correct in thinking need new plugs if sometimes the engine hesitates to start?
thank you
Can you define hesitation? Can be fuel related, electrical, weak battery etc. Bad plugs can certainly cause a hard to start condition but if they are that bad you would likely suffer other performance degradations including poor fuel economy. I would stick with the OEM plugs and there are plenty of threads on this site to help you.
Hesitation: turns over but sounds and feels like it's choking a bit before running smoothly in idle.
Not sure of your maintenance history but I would start with a good tune-up with careful attention to coil pack condition for cracks etc. Clean the MAF with MAF cleaner and go over everything with a good look at vacuum lines, hose connections etc. If the hesitation still exists then you will need someone with a durametric or PIWIS reader to start looking a little deeper.
