error codes which I got from Durametric
Can anyone tell me what these mean.
This first list is from : alarm unit:
16
Signal from airbag
Status: not present
Frequency counter: 2
21
W lead (DME immobilizer)
Status: not present
Frequency counter: 3
49
K lead
Status: not present
Frequency counter: 1
25
W lead
Status: not present
Frequency counter: 8
33
Interior sensor faulty
Status: not present
Frequency counter: 9
41
Transponder pill faulty or not
present
Status: not present
Frequency counter: 11
47
Control locking synchronization
Status: not present
Frequency counter: 25
34
Status: present
3
Door lock barrel open actuated
longer than 60 s
Status: not present
Heating & Air Conditioning
Current Fault Codes
20
Combi-interface fault
24
Power supply (terminal 15)
fault
28
Footwell defr. flaps motor fault
Motronic 5.2.2
Current Fault Codes
P1602
Porsche fault code 660 - CAN timeout - instrument cluster
P1571
Porsche fault code 39 - Immobilizer
P1691
Unknown DTC: 1691
P1600
Porsche fault code 216 - CAN timeout
PSM
Well, the reason why I want to look this codes up is cause they been there for a long time... Hence I wanted to look them up. You had suggested using the Durametric which is what I did and came up with these codes. So that is why I posted them. Do you have a site for the codes. I do not have the manual for it. also I dont want to spend a ton of money at a repair shop and get ripped off when the car is worth like 9k and spend couple of grand cause its a "porsche" , I live in NYC where they like to make people spend their money over minor issues.
All the engine codes are listed here under the DIY Menu -> OBD-II P-Codes
My point on the alarm codes is that something as simple as changing the battery can cause those. In the service manual when disconnecting or changing the battery Porsche says " scan and erase all codes". They do this because disconnecting the battery or changing the battery can cause false codes.
If you clear the codes and drive the car for a day - the codes that come back are real fault codes. I am trying to save you time and worry.
34
Status: present
On the alarm unit the only code that is currently present is 34. The frequency counters are the running total of each time they are present. The Durametric Tool cannot erase the counters(not sure about PST2 or PIWIS.)
Do you have any other problems. When my car was parked the car alarm would go off randomly. Upon checking the codes I had an alarm code 23. I determined that I had a faulty interior infared sensor. I replaced the sensor and no more inadvertent alarms. The frequency counter stopped counting at 4 and has been at 4 for 2 years. I also had an Alarm Code 21. For me it has never been present. I'm thinking it might have been an issue for the previous owner.
Here is a screen shot of my Durametric Screen Report just last week.
Edited by kbrandsma
You replaced interior sensor.. Where is this part? can you give me a part # or and location for it, Thanks. My problems are that my courtesy interior lights and some of dashboard lights do not turn on at night when the headlight switch is in the on position . Also my convertible top does not move unless I have my headlight in the on position. The e-brake is up and its not the brake light switch cause it has been checked... That is why I decided to use my duramteric.
Edited by clb0099
The interior alarm sensor is part # 996.618.210.02- cost about $80.00. You can also try checking your alarm sensor. Make sure the top is up and latched (if top is down insert the red clip), put a window down, set your alarm, and then reach in your car or flash a hand around the interior to activate the infared sensors. If the sensors work your alarm horn will go off.
If you have checked your ignition switch you might want to check your main head light switch. Here is a couple links that might be useful.
Another Light Switch Electrical Problem
Switch Removal
