86 944 Blocked Drain Holes
I have a number of blocked drain holes it seems: Was wondering if anyone knows how to clean the drain hole under the gas cap. I've tried pins, wire... nothing will go down there
Also I read there are drain holes where the pins close the hatch - if so they are also blocked.
The other ones are at the firewall behind the fuse box & other side that prevent water getting in the vents in heavy rain... which I had happen recently - I can't even find those ones.
thanks
Mesh
Thanks will try that.
Can you tell me where the drain holes are that prevent water getting in the vents when it rains heavily - one is supposed to be behind the fuse box, & the the other on the other side, but they're certainly not obvious - to me anyway,
