Does anyone know the procedure to alter the direction the headlamp beams dip in. I have a UK spec RHD 968, which I'm now driving in Holland. As part of the process of registering the car with the Dutch authorities, I have to change the headlamp dip from right to left. Does this require new headlamp units or can it be done using the existing set up?
Any advice gratefully received - thanks
